Dabar yra Tre Spa 21, 2026 5:45 am
 Pranešimo tema: 9-3 SS, SW elektra ir kiti
StandartinėParašytas: Pen Bal 01, 2016 9:17 pm
Grazvis rašė:
Ką galima veikt su tech2
What Tech II changes can I make to the car?
This describes non-user programmable Tech 2 options for the 9-3 Sports Saloon. These adjustments must be made by your Saab dealer or by a Saab Specialist who is equipped with Tech II device. This list is current for 2003 & 2003 model years. This is useful to print out, think about, and then take to your dealer.
Options may have been added, subtracted, or changed. Email me with updates!
Panic Alarm: Disables or Enables the Panic Alarm via remote control
Boot/Trunk/Trunk Unlock: What happens when the Boot/Trunk button on the remote is triggered. Settings:
Single Press Unlock & Open: Single press of the remote or door switch will unlock and open boot
Single Press unlock / Double Press Open: Single press of the remote or door switch will unlock; double press will unlock and open boot.
Boot/Trunk Lock After Closing: What happens to the Boot/Trunk/Trunk lock when closing it. Settings:
Yes: Automatically lock Boot/Trunk/Trunk on closing
No: Boot/Trunk/Trunk can be reopened using micro switch button located on the Boot/Trunk/Trunk
Boot/Trunk/Trunk Lock After Drive Off: Should the Boot/Trunk/Trunk be locked at drive off or after 30 seconds? Settings:
Yes: Boot/Trunk will automatically lock when vehicle increases speed
No: Boot/Trunk will remain closed, however will be in the unlocked condition if No was selected in the previous option.
Door & Boot/Trunk Unlock at Key Out: When the is removed from the center console should door/Boot/Trunk be unlocked? Settings:
Yes: All Doors & Boot/Trunk will Unlock when the Key is removed from the Ignition Switch If Driver frequently locked all Doors when driving this feature would be beneficial.
No: Doors and Boot/Trunk will remain in the same condition as they were prior to key removal
TSL Locking Logic (Theft Security Locking/Deadlock): Settings:
TSL at first Press: Default Setting. All Doors will lock in Deadlock Mode
TSL at second Press: All Doors will lock in Deadlock mode at the second press of the Remote.
Lock/Unlock Acknowledge: Settings:
None: No acknowledge will be visible
Indicators: Indicators will blink as confirmation
Follow Me Home Function: Settings:
Tail Light: When selected Tail Lights will be illuminated
Back Up Light: When Selected Reverse Light will be activated
Tech 2 Body Exterior Lighting & Horn
High Beam Follow me home Active Time: Follow Me Home Active Time can be adjusted between 0- 10 minutes, Settings:
This Feature can be turned on or Off: Yes/No can be selected.
Low Beam Automatic/Low Beam also in Position 0 (light switch) - Yes/No
bullet
Daytime Driving Lights can be activated
Parking Lights, Settings:
Act as Lead Me To the Car Light.
Park Light On Reminder, Settings:
On
Off - If Ignition is turned Off and the parking lights are active, Driver will be warned if set to on.
Show Trailer Light Outage: REC will detect blown trailer light and display on SID, Settings:
Yes
No
Trailer Light/Fog Light: Fog Light Rear will be disabled When Trailer is connected, settings:
Yes
No
Horn Lock Unlock Acknowledge, Settings:
On: Horn will honk when car is locked
Off: Horn will not honk if car is locked
Tech 2 Body Locking
Panic Alarm Activation (Vehicles fitted with /Alarm only)- Panic Button/Locking Switch, Central Locking Switch Driver/Passenger, Settings:
Panic Button on Remote and locking switch inside vehicle will activate alarm
Panic Button will activate Alarm only
Locking Switch inside vehicle (driver /passenger will activate alarm only
No Panic Alarm function required.
Unlock Logic, Settings:
All at first press : All Doors will open & Fuel Lid will unlock if the Driver or Passenger Door Switch is activated
Driver Door & Fuel Lid at first press : Only the drivers Door will unlock & Fuel Lid will unlock when door switch is activated
Remote unlocking One Press, Settings:
All at first press: All Doors will open & Fuel Lid will unlock if the Remote is pressed
bullet Driver door & Fuel Lid at first press: Only the drivers Door will unlock & Fuel Lid will unlock when the Remote is pressed
Tech 2 Body Front Wipers/Washers
Additional Wipes: Below this Vehicle Speed Adjustment/Used after washing the windscreen. System will activate an additional wipe to remove excess water run off. Therefore Driver can wash screen without turning wiper on to wipe runoff. The Vehicle Speed at which the additional wipe feature cancels can be set. Number of Wipes after wash Number of Wipes after wash is programmable. The number of wipes can be set between 0-10. Settings:
Yes: Extra Wipe enabled
No: Extra Wipe not enabled
bullet Front Washer: Number of Wipes after wash Number of wipes can be set between 0-10 Recirculation for 30 seconds after wash
Bi Xenon Only Washer activation time, Settings:
Yes
No
Washer activation 1: Reduces or increases the amount of washer solution dependant on driving conditions Washer activation time for the first wash can be set between 0.1-2.0 seconds
Washer activation 2: Reduces alcohol smell during windscreen washing. Settings:
Yes: Recirculation activated to reduce washer solution alcohol smell (AC/ACC recirculation)
No: No Recirculation during windscreen wash
Washer activation time for the second wash can be set between 0.1-2.0 seconds
Headlight Washer Blocking Time (Bi Xenon only) Headlight Washer Blocking Time ; Determines the time required before an additional headlight wash will be performed, Settings:
Default setting is 2 minutes. Driving conditions may dictate less or
more time before a subsequent wash is actioned. Adjustment between 0 seconds to infinity.
Tech 2 Body Heating & Ventilation
Air Distribution Floor Mist Delay at Start Up
Open Defrost in Hot Climate: Delays the Air Distribution to the screen on start up to reduce fogging the inside of the screen. Select yes to allow air to be directed to screen during AC cooling operation. Select No if Screen is fogging up on the outside of the screen during AC operation and high humidity. Settings:
Yes
No
Air Flow Fan Mist delay at Start Up 0-30 seconds, Delays fan operation for selected time to reduce screen fog up ACC will control recirculation, can be overridden by manual selection, however, will revert to Automatic on start up. Recirculation or Fresh will be Manually selected and maintained on next start. Alcohol smell from washer fluid is reduced.
Recirculation Semi Auto, settings:
Yes
No
Recirculation Manual, settings:
Yes
No
Recirculation After Wash 30 seconds, settings:
Yes
No
Rear Demist, settings:
Yes
No
Rear Demist Activation Time 5min - 20minutes
Tech 2 Body Theft Protection
Drivers Door Doors & Boot/Trunk will unlock at key out
Door Lock if not opened.
Door Switches Unlock Function Yes/No Door will automatically lock if unlocked and not opened.
These are the same adjustment items as unlock logic.
Passenger Door Same as Drivers Doors Adjustment items
Rear Left Door Same as Drivers Doors Adjustment items
Rear Right Door Same as Drivers Doors Adjustment items
